RESULTS: Stage 1+ w/ DNP manifold, O2 housing, Titanium 16G w/ 10.5 Housing
#136
Originally Posted by ShapeGSX
To be honest, I doubt you will see much of a change with a 16G going from HKS cams to some other brand. The limit I have run into is how much air can get through the compressor inlet.
#137
Originally Posted by cjb
All things being equal though, I'd say that the hotside is going to show more of an improvement than a manifold... Agreed?
#139
Originally Posted by ez76
Due to intake restrictions? How would it look when tuning if this were the case?
If you are talking pump gas, then there may be some gains to be had, but I doubt it.
#141
Incidentally, I ran 11.825@117.55mph with a 1.676 60-ft last night at the track with my Evo III 16G (which has the same compressor and exhaust wheel as the Evo VIII, I believe, just mirror images). There is a lot of potential in a 16G!
#142
l8r)
#143
What cam setup did you end up with, as you talked about trying different ones.
igo4bmx
13
Nov 25, 2008 02:06 PM
Boost3dxEvO
11
Oct 14, 2007 11:45 PM
Bosshog
31
Jul 24, 2006 08:45 AM
turboDan
24
Jan 31, 2006 05:00 PM
rlazer5000
16
Jan 24, 2006 09:43 AM
16g, 505, cfm, dnp, dyno, eclipse, evo, gsx, manifold, mitsubishi, td05hr16g69t, td05hra16g6105, tdo5, tdo5h16g10cm2, tdo7s25g17cm2, titanium, tubular, turbo
