RESULTS: Stage 1+ w/ DNP manifold, O2 housing, Titanium 16G w/ 10.5 Housing
Old Aug 12, 2004, 08:20 PM
ez76's Avatar
ETHAN.117:
  • XEDE w/ XEDEFlash
  • HKS 264/272 cams
  • Vishnu signature series dump-back exhaust w/ high flow cat
  • Samco I/C hoses
  • 100 octane
Added in ETHAN.144:
  • DNP exhaust manifold (Jet Hot 2000-coated)
  • Evo 6.5 TME turbo (titanium big 16G w/ 10.5cm^2 turbine housing)
  • DNP O2 housing (Jet Hot 2000-coated)
  • MR diverter valve
  • Denso 720cc injectors
  • Thermal wrapped downpipe
Picked up about 15 peak whp but I am pretty darn surprised by how much midrange torque I picked up!
Attached Thumbnails RESULTS: Stage 1+ w/ DNP manifold, O2 housing, Titanium 16G w/ 10.5 Housing-stage1-_100_dnp_ti_hp.jpg
ez76 is offline
Old Aug 12, 2004, 08:37 PM
MalibuJack's Avatar
Nice.. Its definitely nice to see my efforts won't be wasted (I have a similar combo).. Nice numbers..
Is the turbo the real TME turbo? or the TD05HRA-16G6-10.5t?
MalibuJack is offline
Old Aug 12, 2004, 08:44 PM
ez76's Avatar
It is indeed the turbo from the Evo 6.5 RS TME.
MalibuJack, thanks very much for inspiring this set-up!
ez76 is offline
Old Aug 12, 2004, 08:49 PM
lambtron's Avatar
The car feels A W E S O M E!!!
lambtron is offline
David@Vishnu's Avatar
Evan The car is pretty darn impressive at tip in and powering out of ocrners. Get down here!
David@Vishnu is offline
Old Aug 12, 2004, 08:54 PM
Big mistake the tron is dropping it off
Old Aug 12, 2004, 08:58 PM
MalibuJack's Avatar
I'm so glad someone got to use the information.. I STILL haven't put my turbo in..
Old Aug 12, 2004, 08:59 PM
MalibuJack's Avatar
You should try the GM Solenoid mod with the XEDE.. you can get the car to spool even earlier..
[EDIT] Sorry Dave and Shiv, I got a little excited that I never really completed my thought.. my point was you can gain some improvement in the boost stability, and how the boost comes on by using a restrictor system with a GM solenoid in place of the stock bleed system.. Sorry guys, it was an incomplete thought.. Too many late nights working on obscure projects..
Old Aug 12, 2004, 09:07 PM
GTVEVO's Avatar
Do you have your boost and AFR sheet to post up as well on the same runs? I would like to compair those as well. If so thanks.
GTVEVO is offline
Old Aug 12, 2004, 09:13 PM
shiv@vishnu's Avatar
This is not true.
Shiv
shiv@vishnu is offline
Old Aug 12, 2004, 09:18 PM
MYEVOVIII's Avatar
Originally Posted by shiv@vishnu
This is not true.
Shiv
Is it true that with the AEM it works better I know of a few who say it works much better with the new Gm solonoid. Why would it not work well with the Xede?
MYEVOVIII is offline
Old Aug 12, 2004, 09:20 PM
Smogrunner's Avatar
Very impressive with a cat and 100 octane. No CAT and C16 might equate to much higher dyno numbers.
Smogrunner is offline
Old Aug 12, 2004, 09:21 PM
MYEVOVIII's Avatar
Would you get similar results if you just upgrade the housing to the 10.5 over stock? I know some have hinted a little about this. But I am unsure how it would work. How much is this turbo and is it still a twin scroll if not what manifold do you need where can you get it. Sorry about all the ?'s just excited about this possible upgrade path.
Old Aug 12, 2004, 09:26 PM
on the internet? not flaming just asking people to be reasonable and logical Mali Jack please just humbly think about that statement and I know if anyone can its you see why it is incorrect
David under shivs
Old Aug 12, 2004, 09:29 PM
Is everuone missing the torque
Quick Reply: RESULTS: Stage 1+ w/ DNP manifold, O2 housing, Titanium 16G w/ 10.5 Housing
