Water injection? No, NITRO injection!
C'mon guys...just a wee little bit! It takes 20% less oxygen to combust Nitro so, with just milliliters of Nitro, we could pickup HUGE HP! A little too much and we could pick up...............the head we just blew off the car at the neighbor's house a block over! What a concept. I don't think it's ever been done on a street car....hmmmmm.
-chris
-chris
Registered User
Go to Supraforums.com and look for posts by Anarky. He's the man for alternative fuels in both knowledge and execution. He is currently converting his Supra to use staged diesel Turbos and run on propane and methanol without a throttle-body. He has had several posts about Nitromethane injection.
Registered User
The propane is going to be used for light throttle as it operates without a throttle simply by varying the flow. It burns cool also, you can't use gas on Diesel turbos with vanes (no wastegates). The methanol will be used for high boost. Head over to the Supraforums and check out his posts. Everyone doubted him on his AEM Computer controlled methanol injection kit, and then he developed the kit, sold it for $300 and ran 30PSI on a T78 on pump gas with the stock fuel system.
