Stupid Water/Alky injection Question
I have searched and haven't really found the answer.
I dont know if you can think of water/alky injection like this but heres the question,
What is the estimated octane of:
91 oct. + 100% water injection
91 oct. + 50/50 water/alky
91 oct. + 100% alky
91 oct. + 100% alky
Your question is phrased incorrectly... but you already suspected that.
Water is valuable because it cools off your pistons and cylinders. Hot pistons and cylinders cause the gas to burn too early, unevenly, or in the worst case, to explode. Water also "steam cleans" your pistons and cylinders and removes carbon buildups. The carbon can also cause uneven heating so it is very good to remove.
I will leave the discussion of alcohol to someone else.
strike
strike
water works.
strike
strike
strike
strike
I know what water does when its injected.
just remember to maintain that santoprene diaphgram in your pump, it will fail when you least expect.
Originally Posted by Yaroslav
I run 93+100% meth on 33psi without any problem
Evokid,
I think that is one of the best if not the best question I have seen since I am in this forum. Definately a question that many people have thought before.
I want to add another question to that. What are the prices of Alcohol, methanol and water liquid in order to run it on a alcohol/methanol/water kit?
why waste your $$$..hardly any hp increase from 3 tests ive seen and one we did..
I gave mine away.1-10hp increase.. its a business..theres a sucker born every minute
erm... i think you misunderstand what is going on here. you should see NO power increases from water injection and very minimal increases from alcohol injection. the purpose of the injection is to reduce knock/detonation so you can increase timing and boost pressure by insane amounts. the power increases come from the timing and boost changes, not from the water/alcohol injection directly. clear?
strike
