Nitrous jet VS Mxx Mcmaster jet for DIY methanol kits
I see some of the DIY guys are using NOS fan nozzle with nos adjustable jets for thier alky/water kits. Most guys are using the fluid nozzles from mcmaster car that are labeled M5, M10, M15 ext.
Has anyone any testing or comparasons between the two to see spray pattern or flow rate? Any opinions from first hand use?
When my shurflo pump arrives Ill hook some all up (I have M5,M10,M15 as well as nos fan nozzles and a large variety of jet sizes) and see if I can get pictures of the spray and measure delivery.
I also want to see how using a nitrous wet fogger nozzle works when there is no nitrous flowing. The plan for my talon is to run a direct port nitrous kit for 4 wet foggers and use a shurflo pump to run methanol to the fuel solonoid. Wonder how the spray pattern and atomization will be when the meth is flowing without any nitrous oxide?
StreetThisEvo
Mar 25, 2014 03:43 AM
browningderek
19
Mar 8, 2011 11:22 AM
ct9a gsr
10
Jun 14, 2006 10:46 PM
DSMotorsport
Dec 28, 2005 07:22 PM
