Snow Performance questions and answers...
#362
If I am reading everything correctly, the pump and safe injection is working... what exactly is not working ? I am assuming be default that it is not spraying ..is this correct ??? if so , what system / setup are you using ? Boost or MAF and how is it setup ?
#363
take the red wire ( power wire ) and connect it to a hot wire. Make sure that the black wire is grounded. Pretty simple actually. DO NOT RUN THIS LONGER THAN A SECOND OR TWO WITHOUT FLUID IN THE SYSTEM. Just long enought to hear it "prime" or pump for a 1/2 second. Should be instantaneous when the red wire receives power.
#375
Anyone have pics of the kit installed in the trunk?
Also, how hard is it to hook up this kit using the stock winsheild washer fluid tank, that would ebe SWEET. I was looking at SMC bc of the ease of install and how it can be hidden in the trunk. However, no failsafe doesnt make me feel good at all.
