Snow Performance questions and answers...
#424
That WGA doesnt work when you have turbo upgrade - the seal breakes
#427
Ok, I did put stock WGA on the car, before meth, it was holding 24psi no problem! adjusted MBC and on meth 26psi. I'am thinking the spring on Forge WGA is not stiff enough. I will talk to forge motorsports directly.
Question: Do you guys know why my Green LED - thats when meth. gets activated keep burning out? I even use 12V LED and same problem. Maybe i should put resistor?
Yes green led is hooked up to the pump wire.
#428
You mean that you keep replacing the bulbs? Check all the wire connections associated with the green LED so that there isn't too much current being thrown at it...just an idea!
#430
yea if the wiring is fine, the wire may be faulty somehow, i just got my kit yesterday and can't wait to install it, and i got a low level indicator too, so does anyone know how to mount that in the tank and like which way, because there is a flapper and i don't know which way i should mount it??
