Snow Performance questions and answers...
Old Mar 3, 2008, 07:29 PM
  #676
Ultimate CC's Avatar
went out today
Old Mar 3, 2008, 07:43 PM
  #677
Evoryder's Avatar
oh yeah... 1 down 3 to go
Old Mar 3, 2008, 07:57 PM
  #678
woot woot...
Old Mar 4, 2008, 03:11 AM
  #679
Evoryder's Avatar
nice ebay store
Old Mar 4, 2008, 09:44 PM
  #680
BCOZEVO's Avatar
Just getting my setup done, starting tuning and was looking for a little help deciding on my target AFR's
25PSI, 375ml/min nozzle, stock injectors, and 75% meth and 25% windshield washer fluid.
I have been aiming for 12.3-11.9 does that sound about right?
Old Mar 5, 2008, 06:44 AM
  #681
Evoryder's Avatar
12.0-12.1 with that amount of meth and boost. you can take it to at least 27psi and still be somewhat conservative for having meth. If you don't have a failsafe...stay at 25psi. 27-34psi + 100% meth and 12.1-5 a/f = power. Go easy on the timing and shoot for a cleaner a/f.
Old Mar 5, 2008, 06:57 AM
  #682
BCOZEVO's Avatar
Good timing I was just getting ready to do a flash
Thanks for the help
Old Mar 5, 2008, 01:17 PM
  #683
nice ebay store
thanks, been trying to work on it slowly and then I have to redo our regular website when I get some time...
Old Mar 8, 2008, 08:45 AM
  #684
BCOZEVO's Avatar
I have a issue with my Snow stage 2 kit where the Rear washer spraying when the pump is on.
Please take a look and see if you have any ideas, its not funny anymore like it was at first and waisting my meth.
https://www.evolutionm.net/forums/sh...d.php?t=330030
Thx.
Old Mar 8, 2008, 12:22 PM
  #685
Evoryder's Avatar
i don't understand how the rear windshield wiper is spraying if the pump is pulling from the resevoir...
Old Mar 8, 2008, 01:12 PM
  #686
im thinking electrical maybe, that is very odd nonetheless
Old Mar 8, 2008, 09:44 PM
  #687
BCOZEVO's Avatar
I am going to disconnect the rear windshield waterline in the morning and see if the front sprays out at all.
I know it’s not electrical because I disconnected the power to the windshield sprayer’s pumps tonight and the back still sprayed a bit.
I also remember the top popping of my tank twice before I noticed this issue, I just thought I did not put it on tight even thought I thought I did, I am thinking what ever is causing this "back pressure" I guess you can call it that is what popped the top off my tank twice and I did not see the sprayer then because the pressure was escaping out of the open tank top.
But if it is pressure that not supposed to happen is it? I am reading of tank venting and stuff but that's just for fumes correct? Not for pump back pressure?
When I installed the kit I turned the pump 1 1/2 turns clockwise the raise the pressure but that would not cause this right?
Old Mar 9, 2008, 06:51 AM
  #688
SlowCar's Avatar
check tubing on pump inlet/outlet
Old Mar 13, 2008, 07:40 AM
  #689
BCOZEVO's Avatar
Ok got the issue all figured out, it was the pump / hose direction like slowcar posted. After testing the system the other day my bro did some hose management in the trunk to clean everything up. I did not know he disconnected and reconnected the hoses. When he hooked the hoses back up to the pump he put the lines backwards and pressure from the UICP under boost was pushing into the Meth tank causing it to pressurize and spray out of the rear windshield washer.
Thanks for all your help everyone BACK to TUNING MA HAH HA
Old Mar 13, 2008, 08:50 PM
  #690
Buschur_TSI's Avatar
Any word on when the safe injection will be back? The weather is starting to get nice and I want a kit bad,but I am not going to do so unless it hasa failsafe
Quick Reply: Snow Performance questions and answers...
