Snow Performance questions and answers...
Old Mar 14, 2008, 03:35 PM
  #691
BCOZEVO's Avatar
Use the Injection Fail Safe by Labonte MotorSports its like the snow one that never happened but 100% meth ready.
https://www.evolutionm.net/forums/sh...d.php?t=306767
Old Mar 17, 2008, 04:24 PM
  #692
Ultimate CC's Avatar
Snow Performance now has new 2.5 Gallon Reservoirs in stock. Add more capacity and maximize your system range without taking up excessive space.
The new 2.5 Gallon features a compact design that maximizes capicity without taking up a lot space. This new larger reservoir replaces the old 7 Quart Reservoir without an increase in price. This means more value for your money. Check out the new 2.5 Gallon Reservoir
Old Mar 19, 2008, 10:34 AM
  #693
Evoryder's Avatar
pm'd
Old Apr 14, 2008, 07:27 PM
  #694
all pms returned...
Old Apr 17, 2008, 02:51 PM
  #695
leecavturbo's Avatar
how come i read so much about 100%
meth usage when SP do not recommend it?
i thought it was proven fact that 50/50
was the best setup?
Old Apr 17, 2008, 06:20 PM
  #696
Evoryder's Avatar
was the best setup?
cause they design and test their products to work on 50/50 and they do not recommend 100% Bbecause it wears the pump internals quicker.
FACT. 100% if tuned properly and more aggressively will yield more results. *close fact*
50/50 = more cooling > more timing > less boost > good for decent power and cooling.
100% = higher octane > more boost > more power
Old Apr 18, 2008, 02:22 AM
  #697
Old Apr 23, 2008, 02:10 PM
  #698
MR06Evo's Avatar
Which pin in the evo IX ecu do you tap for the yellow wire in the kit? Its the wire thats suppose to go to the maf signal. Thanks!
Old Apr 25, 2008, 06:36 PM
  #699
jutilat's Avatar
I just bought an Evo VIII with the snow performance kit installed on it. I'm a bit ignorant with the logistics of a methanol kit. It has the 150psi pump, a 2.5 gal tank in the truck, the pump is mounted in the engine bay. I have a little allen head that tunes the methanol to spray at a certain boost level 18psi I believe, the dude I bought the car from tinkered with it and i'm not getting any signal from my green led indicator light that it's pumping meth at all, my resivor stays at the same level. I noticed he tapped into a fuse (i know, half assed) to get the 12v power to run the led. I want to tap into another power source and do things the correct way. Also, what way would I turn that allen head to decrease the sensitivity to activiate the meth at around 18psi, i think he messed it up and has it way high. I'm running 22 pounds of boost and the meth is a just there as a fail safe for 18+psi. I'm just learning so bare with me Any help or suggestions would be great.
Old Apr 30, 2008, 07:18 PM
  #700
Have both of your questions been answered if not drop me a pm and I will do so...sorry I have been busy and haven't had much time for forums...
Old May 8, 2008, 10:24 AM
  #701
ace75's Avatar
will the snow 20011 kit work on the evos?
Old May 8, 2008, 06:52 PM
  #702
no the 20011 is not for evos...its for V where evos are Hz...
Old May 8, 2008, 09:41 PM
  #703
grenade's Avatar
Is there a GOOD Switched 12v source in the engine compartment for the Control box ? TIA.
Old May 8, 2008, 11:34 PM
  #704
TKEVO's Avatar
Originally Posted by Ultimate CC
when you get the SI you will also need the wastegate solenoid for most evo setups..
Would I need the wastegate solenoid running with the stock turbo?
Old May 8, 2008, 11:36 PM
  #705
TKEVO's Avatar
Alright now. Snow keeps telling me the Safe Injection will be out in a few weeks. They have been telling me that since February and I'm kind of getting sick of this. I'm not putting my meth in without it.
Quick Reply: Snow Performance questions and answers...
