Snow Performance questions and answers...
#715
It seems I have a problem with my snow kit I recently installed. I based my install on the one that was first shown here:
https://www.evolutionm.net/forums/sh...tealth+install
The car dyno'd fine and it activates as it should. However, when I let the car sit overnight the remaining amount left in the tank empties out into the IC piping. You can tell at startup that meth is in the IC piping and I had to let it clean itself out.
Do you have any ideas or recommendations on how to fix this?
#717
http://www.snowperformance.net/product.php?pk=20
Thanks! I assume this would cure my problem. I am just curious since I haven't found other people with that problem..
#719
I had the same issue with my original trunk mount setup. It got past the throttle body and you could see it in cylinders...had to siphon the meth out and needed a new starter due to it. I never got a chance to try the solenoid upgrade with my trunk setup and moved it to the front of the car.
I have a solenoid valve that i purchased from Dan that is brand new. It will only work if you're using less than 100% meth.
