Alky injection using Methanol
#31
That piston damage is nothing short of detonation damage. You need to change your tuner. Its got NOTHING to do with alky mixing with oil.
And I wouldn't trust anyone who says they lost a cylinder from dropping a valve guide and having oil mix with methanol. Once a valve guide drops you are going to loose that cylinder no matter what.
#32
Originally Posted by Ivan_C
I was going to leave this along, but I'll bite. Let's see if we can agree on some things first. Methanol will pre-ignite on hot spots in the cylinder, agreed?
Ok, so we know it can and does violently pre-ignite on hot spots.
So how does the oil come into play. Well oil has a problem of leaving ash deposits when burnt. These ash deposits can form hot spots in the combustion chamber.
You can say I took items out of context, but how many people put detergent free oil in their engine. Last time I used deterget free oil was in an air compressor, I had to go and find it.
So we have hot spots generated from excess oil in the combustion chamber being burnt with the fuel. Thus providing methanol the opportunity to pre-ignite and distroy the piston.
Ivan
Ivan
SBR INC
Jan 20, 2010 08:15 AM
Ivan_C
Jul 23, 2008 05:30 AM
