torn between these alky kits. help
Guys i have searched and found two alky kits iam torn between, the smc kit and the aquamist kit. Since iam a novice in the alky department iam alittle lost in which kit to get. I like the aquamist kit due to the dds3 system. due these two kits have reliable issues, and can you use denatuer alcohol in the aquamist kit. btw does the aquamist kit need a special additive due to seals in the tank?. any info would help. thanks
Originally Posted by smokedmustang
Get the AMS one!!! Got bigger & stronger pump! Go look at their site.
Originally Posted by 9xfaster
I don't know much about the aquamist, but I have the SMC in my IX and I love it. It mounts in the trunk, and I've never had a problem with it.
Originally Posted by j3ffw19
could i hook up the dds3 system to it?, i also want to keep the windshield washer bottle, do they make a holding tank that i could install on the driverside of the trunk?
can the aquamist run alky or is it just water injection, does it need a special additive to prevent pump failure?
Originally Posted by blackevo110
talk to Steve at SMC too...just get a feel for what ur looking into...i have SMC myself.
Originally Posted by EvoTio
The Aquamist pump was not designed to be run on denatured alcohol. It will run a methanol and water combo. It can be modified to run a very high percentage of methanol with upgraded seals, you would need to contact Richard Lamb of Aquamist for more information. j3ffw19, I'm glad you're thinking of failsafes. Most of the "alky" users on this forum either don't know what they are or don't bother to use them. Remember it's your car and it's up to you to try and protect it from catostrophic failure in case there is a malfunction. I still say Aquamist is the best around .
I duplicated this set up and received help from him and Richard when I needed it. Pm me if you have questions.
snow performance kit from gruppe-s has a failsafe, has anybody used the dds3 with that kit.
pretty much what iam looking for in a alky kit is, trunk mounted, has failsafes, can run denatuer alcohol, compatible with the dds3, and ofcourse reliable. Are there any new kits coming out with more failsafes, upgraded pumps.
