What spark plugs should on my evo 9 with a snow meth kit running at high boost.
#31
The tial bov will hols more than a sock recirc, and may cause you to see small jumps in your mixture (on the rich side) when deceling and shifting. Most evo's don't have any issues going atmospheric.
I am guessing you are flashed, so minor changes in your tuning will compensate for the bov. Better intercooler is always better, as you are running higher boost than stock, and therefore operating out of the factory parameters for your turbo. Any failsafe you can put on your car is better than none.
You can run upwards of 30psi on the stock IX turbo. With intake, TBE, and an agressive tune w/ alot of meth, you can expect 350-370ish whp, some have claimed more. I'll throw you my dyno #'s the end of this month.
If you want, talk to ChadEvo. Send him a PM, he did my tuneing.
BTW, what wideband are you using?
nsheasley
Dec 7, 2015 07:11 AM
Evo8you2007
Mar 7, 2008 02:19 PM
blackonblackevo
Jul 2, 2007 07:02 PM
