Evo 9 RS Aquamist 2d (pics)
Old Feb 14, 2007 | 09:51 AM
SlowCar's Avatar
Originally Posted by cij911
Thanks Abner -- I have seen the videos. I thought the magnetic / piston pump was supposed to be the best? What is the cost difference between the two setups and why did Evan not get the failsafe? Thanks again for your help.
Hi Chris, whether you choose the magnetic piston pump or the aquamist custom spec'd high flow shurflo, you can be assured that you are buying the best.
The DDS3 failsafe is a standalone unit. It can be integrated into any injection kit on the market - this unit is the ONLY failsafe on the market that has a both a user definable upper/lower limits - outside this SOA, safe operating area - it can trigger a boost defeating solenoid OR if you run a aftermarket ecu, change map in the event of a fault.
There are 3 LED on Evan's system for fault warning - maybe he can chime in and tell us more.
Old Feb 14, 2007 | 10:11 AM
evoone's Avatar
good job!
Old Feb 15, 2007 | 09:23 AM
esevo's Avatar
There are three leds on this Aquamist system, red, blue and yellow. Red to warn of a failure inside the system blue for pump activation and yellow for low tank level.
As Abner said you can always add the DDS3 later which I plan on doing, but lack of funds and places to put that gauge at the current time doesnt work... I will get it before a good tune... This kit ranges in price around $800 I think.
Old Mar 24, 2007 | 08:33 PM
EvoTio's Avatar
Hey esevo, congrats on your 2D installation. I've had my 2D for many years and and is still working great! Also you gotta love Richards customer support, it's the best that I've encountered so far!!
EvoTio
34
Feb 19, 2006 10:08 AM
vegasboy301
Dec 12, 2005 07:30 AM
vegasboy301
Nov 26, 2005 06:14 PM
snoop
Apr 12, 2005 11:26 AM
Quick Reply: Evo 9 RS Aquamist 2d (pics)
