Introducing the new HFS-1 system by Aquamist
#46
We are unlikely to host another GB again as it is quite hard work.
Richard
#47
The system looks for a preset water flow window when the system is injecting. If the flow is outside the flow window, it will disconnect the factory boost control valve and drop the boost to wastegate setting.
#48
How can the DDS3-v8 fail-safe flow monitoring system be used in conuction with running an MBC or a high-boost wastegate?
#49
You can use the following diagram and the valve made by MAC. Or use an alterntive "normally opened" valve from Clippard (~28 dollars):
http://www.clippard.com/store/byo_el...use_valves.asp
Brent kuz
Sep 8, 2010 08:28 PM
SlowCar
13
Nov 29, 2007 09:08 PM
Richard L
22
Apr 24, 2007 01:53 PM
Richard L
11
Mar 29, 2007 01:30 AM
