Aquamist myths and views... HFS-5
The perrin kit is very much a plug and play system compared to HFS-5. For day to day usage, the perrin kit is *most* suitable. (corrected 22-Apr-07)
For all out power, the HFS-5 has more options.
There are several ways you can save fuel:
- replacing dumping fuel as in-cylinder coolant - dump water instead.
- Enable more timing with low octane fuel - raising the effective octane.
- Run excessive CR or boost and bring the combustion temperature down with Water.
The above conditions are mainly related to medium to WOT. For longer term economy, you need to have a higher CR.
On the evo, you can raise the effective compression ratio by increasing the boost.
If you are raising the static compression ratio as described by you, you wil have to run WI from mid throttle onwards all the time.
If you inject water at those cruising conditions, you might get a degree of two advance due to absence of knock when the active knock control system slowly advancing the timing. Knock can exist because the afr is very close to stoichiometric
Please contact Jack (our US representative) John Blalock [jackblalock(AT)gmail.com]. He will help you getting one.
Alternatively, you can ring try anyone form the link below:
http://www.aquamist.co.uk/sl/plist/frm-4-USD.html
Richard
Richard L
149
Feb 27, 2016 03:01 PM
SlowCar
13
Nov 29, 2007 09:08 PM
Richard L
11
Mar 29, 2007 01:30 AM
Richard L
97
Mar 7, 2007 04:00 PM
Richard L
15
Jan 26, 2007 03:14 PM
