Shurflo pumps of major WAI kit manufacturer
#46
cj...
Thanks for the correction, I knew I have missed something out. In any case. The results seemed to be in agreement in general. I think I will do some tests to prove this.
If the result proved to be different, we will soon know what the other variables are and pehaps iron it out. R&D starts with basic science.
#47
Proggressive alky triggered at 5psi, max boost 25psi.
time it takes boost to go from 5-25psi = .5-2.0 seconds depending on turbo.
time it takes 60watt pump to go from turn on voltage (5psi in this case) to endind voltage (25psi) is about .1 second. The 150 watt pump may do it in .08 seconds but BOTH do it WAY faster than boost responds so the arguement is irrelvant as I see it. These numbers are estimates but I think they are close enough to prove my point. Un electric motor shines on the low end with instant massive torque. Turbo spool can never be as fast. Even during shift recovery when the turbo spools the fastest it will still spool a good bit slower than the pump reaction time.
So yes your 150watt pump responds faster. But in a progressive sytem the 60watt pump responds faster than needed. Should be the end of the discussion, but prolly wont be.
#48
The discussion would never started if someone hadn't brought this up in the first place. Making sweeping statements in public just to gain brownie point is unnecessary. I totally agree with you on the relevancy regarding on application.
Tracking boost does not require fast response, but tracking fuel flow requires much faster response - for this kind of application, response time matters.
I will do the test just as a matter of interest.
#50
Guys -- quit the fighting and address some of the questions...or have the engineers that designed the systems answer the questions...
(1) What is the optimal psi for meth / water atomization?
#51
i don't think there is just one solid answer for this, many variable including nozzle size, mixture % (ie methanol, water, alcohol, maple syrup etc ahaha) as well has hose length and diameter...
#53
Hmmmm...Ok interesting...I am sure there is an answer for pure H2O and suspect the engineers that designed the systems used that to determine ideal motor....
#54
cij911,
Are you looking cooling effect of the combination? Your question covers a broad area. Can you be more specific?
Small Droplet size can evaporate fast but will reach full saturation at a given temperature, air volume and pressure. beyond that point no further cooling is expected at the inlet tract.
Saturated air will carrying the remaining liquid into the combustion chamber, cooling capacity will be fully spent during combustion.
SlowCar
150
Jul 5, 2008 10:38 AM
m4tt VIII
32
Jun 30, 2008 01:25 PM
SlowCar
49
Sep 26, 2007 01:43 PM
