Replacing my SMC pump with another brand
Old Jun 15, 2007 | 05:30 AM
SlowCar's Avatar
by-pass mode shurflos maintain injection pressure by a set of internal valves
on-demand mode shurflos maintain do it by a pressure switch on the pump head, 3 concern with this mode of operation
-leaky pressure switch
-the constant cyclic on/off for pump to maintain pressure - the stop/start action draws a lot of current and doing it many times puts wear on the brushes - stress on the heart of a alky system is not good
-due to the dead band, flactuations in line pressure
Old Jun 15, 2007 | 08:33 AM
Rocket468's Avatar
Shuflo makes lots of models of pump make sure the pump you get has EPDM seals. This solves the most common problem of failure i have witnessed. I have sold several thousand pumps and biggest problem warrenty wise was viton seals. So we switched, them to epdm over a year ago. We hardly have pump have pressure switch or even brush problems. Maybe 1 or 2 a month. Shurflo really makes a good product.
Old Jun 15, 2007 | 08:41 AM
Rez90's Avatar
now you guys have me paranoid about my SMC kit..................bastards.
I've had it for about 3 years now with no probelms......knock wood.............
Old Jun 15, 2007 | 08:48 AM
SlowCar's Avatar
several thousand...r u coolingmist, snow......?
shurflo is big, bulky, takes a lot of power BUT robust
Old Jun 15, 2007 | 08:50 AM
SlowCar's Avatar
you at least run a failsafe right?
Rez90's Avatar
yes i do. i have it wired into the AEM to drop boost when/if the pressure drops.
BUT......ask me if i trust it..............??
Old Jun 15, 2007 | 09:00 AM
Rocket468's Avatar
I am with DevilOwn injection
10 amps max is not really much.
My elec water pump on my car pulls 20amps.
Old Jun 15, 2007 | 09:09 AM
SlowCar's Avatar
i got a aquamist 150W shurflo
Old Jun 15, 2007 | 10:28 AM
mikesevo8's Avatar
So ... has anyone ... er... done a "competative analysis" of the SMC controller ??
Will it work with the higher demand Shurflo pump ???
So Rocket - are you recommending the DevilsOwn as suitable ???
BTW - all the verbage for these pumps talks about water and water/meth .... how do they stand up to alky ??
Old Jun 15, 2007 | 03:17 PM
SlowCar's Avatar
http://www.shurflo.com/pages/new_ind...2-793-238.html
http://www.flojet.com/files/rlf_series_f100-196.pdf
Check with steve@smc if the controller is robust enough to handle the higher current drawn by a shurflo
i will stay away from denatured alcohol...denaturing/fouling compounds to make ethanol undrinkable like...acetone, methyl ethyl ketone aka pvc pipe cement, dichloromethane aka paint remover...although they are ~several %, these solvents are not good for the santoprene/epdm pump internals
have you considered running a simple on/off injection system, parts consist:
-pump
-hobbs switch
-relay
-solenoid valve?
Old Jun 15, 2007 | 09:54 PM
mikesevo8's Avatar
What is the advantage of such a setup ??
I understand how the progressive system works, injecting volume increases based on boost.
How would the on/off system be used ?? Just pick a psi and start spraying?
Old Jun 15, 2007 | 10:49 PM
SlowCar's Avatar
consistency!
...in theory
yep, single setpoint and fire away
williamgasdick
22
Oct 11, 2012 12:01 PM
EvilBlueEvo8
Aug 16, 2011 01:38 AM
Svendiesel
Jul 11, 2010 12:45 AM
Chris@nolimitmotors
21
Jan 24, 2006 10:03 AM
EVO8LTW
17
Feb 8, 2005 07:57 AM
Quick Reply: Replacing my SMC pump with another brand
