methanol mixtures
Old Jun 14, 2007, 08:09 AM
bvdawg13's Avatar
methanol mixtures
ok, so after doing alot of reading and talking to a few people, i have come down to there are a few mixtures that guys are running, its between straight alky or straight methanol of course, but also to mix meth with distilled water, or the windshield fluid and heet (98-99% methanold).
what are the positives and negatives of these mixtures?
also compare prices of different mixtures.
Old Jun 14, 2007, 08:16 AM
El.BlueEvo9's Avatar
100% all the time is too corossive..........I use 50=50 Water and Meth.
Old Jun 14, 2007, 09:38 AM
SlowCar's Avatar
200 proof methanol is only corrosive to reactive metals like Zn, Al...
http://en.wikipedia.org/wiki/Methanol
One of the drawbacks of methanol as a fuel is its corrosivity to some metals, including aluminium. Methanol, although a weak acid, attacks the oxide coating that normally protects the aluminium from corrosion:
6 CH3OH + Al2O3 → 2 Al(OCH3)3 + 3 H2O
The resulting methoxide salts are soluble in methanol, resulting in clean aluminum surface, which is readily oxidised by some dissolved oxygen. Also the methanol can act as an oxidizer:
6 CH3OH + 2 Al → 2 Al(OCH3)3 + 3 H2
This reciprocal process effectively fuels corrosion until either the metal is eaten away or the concentration of CH3OH is negligible.
wetted parts in a WI system include nylon, santoprene, EPDM, nickel coated brass, Buna-N, Nitrile, austenitic stainless, polyethylene, polypropylene, delrin - all fairly stable in the presence of methanol
Old Jun 14, 2007, 09:52 AM
SlowCar's Avatar
lots of good information on this subject from Richard and Jack
on injection mixtures:
http://www.srtforums.com/forums/showthread.php?t=308693
good stuff:
https://www.evolutionm.net/forums/sh...29&postcount=7
Methanol cost about $25 to 30 for a sealed metal drum of +99% purity, tech grade
RO/Distilled water, ~$0.60 from the grocery stall
Old Jun 14, 2007, 10:31 AM
inco9nito99's Avatar
100% methanol, been runing 500+awhp on a DIY kit I made, ZERO traces of anything wearing or washing away.
Old Jun 14, 2007, 11:08 AM
bvdawg13's Avatar
so what are the performance differences besides the cool down factor between 100% meth and 50/50 mix?
Old Jun 14, 2007, 12:12 PM
aqmist's Avatar
Additional octane, but to really take advantage of a high methanol injection mix you need to tune for it......which means that you need to get your failsafes mechanisms figured out, and make sure they work properly.
Old Jun 14, 2007, 07:54 PM
TTP Engineering's Avatar
100% methanol.
P.S. don't **** with Slowcar. He will beat you with technical chemisty textbooks.
Old Jun 14, 2007, 08:07 PM
SlowCar's Avatar
Old Jun 15, 2007, 06:39 AM
bvdawg13's Avatar
Originally Posted by TTP Engineering
100% methanol.
what is the advantage of using 100% methanol vs a 50/50 mix?
Old Jun 15, 2007, 07:50 AM
Higher octane, cooler intake charge, more ignition timing, less knock.
Old Jun 20, 2007, 11:42 AM
bvdawg13's Avatar
so i cant find any straight methanol around me to mix....i was thinking of heet and washer fluid but i heard that heet is bad?
Old Jun 20, 2007, 12:59 PM
dudical26's Avatar
If meth is corrosive to Al, do we have to worry about it corroding our head?
Old Jun 20, 2007, 02:18 PM
packrat's Avatar
On 50/50 mixes- what is the purpose of the water? Only for cooling purposes, or to dilute the methanol a little to make it less corrosive?
Old Jun 20, 2007, 03:03 PM
Yellow heet is 99.9% methanol and available at wal-mart.
Quick Reply: methanol mixtures
