feeding time
When I was researching my setup Richard sent me this
(at 125psi)
1mm = 520cc/min
0.9mm = 470cc/min
0.8mm = 420cc/min
0.7mm = 375cc/min.
0.3mm = 65cc/min
Also
Water = 1 (datum)
Methanol = 2x
50:50 – 1.5x
Hope this is helpful
Duncan
(at 125psi)
1mm = 520cc/min
0.9mm = 470cc/min
0.8mm = 420cc/min
0.7mm = 375cc/min.
0.3mm = 65cc/min
Also
Water = 1 (datum)
Methanol = 2x
50:50 – 1.5x
Duncan
stay away from denatured alcohol...depending on the maker, there can be harmful denaturing agents added that can have detrimental effects on the wetted parts in a WAI system.
methanol, range from $2 to $5 depending on the volume you buy. Call around chemical supply houses, 5 gallon sealed drums for ~$25
SlowCar
150
Jul 5, 2008 10:38 AM
SlowCar
49
Sep 26, 2007 01:43 PM
SlowCar
55
Apr 21, 2007 12:02 AM
4TUN8
46
Mar 30, 2007 05:02 PM
