S-L-X Denatured Alchohol and HFS-5?
Ok guys, so I have found out that my local Home Depot carries this brand of denatured alcohol.
According to the MSDS contain the following:
- 45-50% Ethyl Alcohol (grain alcohol)
- 45-50% Methanol
- 1-4% Methyl Isobutyl Ketone
First, will there be any problems running this with the Aquamist HFS-5 injection kit?
Second, should I run this mixture straight or mix with distilled water for max power?
Third, what percentage of alcohol mixture to fuel is recommended?
Tough questions, but trying to limit the tuning iterations based on others experiences.
- 45-50% Methanol
do not use it....MIK is as bad as MEK, methylethyl ketone, PVC pipe welding cement.
Call around chemical supply houses and get 5 gallon sealed drum of methanol or hotrod shop
it will be great to get meth in a sealed drum - should be ~$30/5gal drum
If you get your stuff from open drum, have them put it into a whitish plastic container to see the color of the meth...I bought some straw colored meth from a hotrod shop when i 1st started using meth. I believe its water/rust contamination.
We based our system on pure methanol. Like abner said, denatured ethanol can be mixed with all sort of chemicals and ratio, you can never be certain if there are any hydrocarbon based substance in the mix.
Hydrocarbon will kill EPDM seal in time. The pump and HSV uses EPDM seals.
Also there are some VP methanol mix contains other chemicals, please stay away from those. HSV is expensive to replace. We have had some reports in the past of bad HSV and pump due to addition of nitromethane (hydrocarbon) in the mix .
scheides
13
Dec 20, 2010 07:26 PM
koullis
Jul 26, 2009 11:54 PM
darwin_evo
17
Jan 7, 2009 10:23 AM
scheides
15
Jul 25, 2008 06:39 AM
