Aquamist Success Story Videos
you can wire in a switch to keep the boost controller working when the aquamist is off, but when the aquamist is on, you want it to turn the boost controller off if a failsafe is triggered. that is why you need a toggle switch to give the boost controller power when the aquamist is off.
Is there a way so the solenoid can be disconnected via a relay (or something else) if the meth is turned off, therefore defaulting to wastegate pressure and allowing the gauge to still monitor boost?
If this method was used then the user would manually have to change the boost setting on the gauge or it would be running the boost set for the meth system, right?
pin 11/12 is a relay in the DDS3 box. so when the meth is turned off, or a failsafe is triggered, pin 11/12 is an open circuit. if the aquamist is turned on, it is a closed circuit until a failsafe is triggered, or you turn the gauge off. you can use pin11/12 to turn off a solenoid and default to wastegate pressure without a problem that is how the failsafe works i'm not sure what you mean by gauge still monitoring boost though... what gauge? the DDS3 gauge?
What I'm talking about can be seen in this video, http://www.youtube.com/watch?v=e0bz4hQG98Q at the beginning. When he shuts off the meth the tru-boost reads "er s" which I'm guessing stand for error - solenoid. Is there anyway to keep the gauge functionality with the solenoid disconnected?
i've not installed or worked with a AEM trueboost controller yet so i couldn't say for sure. but if it is like the stock solenoid you can use the resistor that comes with the HFS package as a load resistor to fool the gauge into thinking the solenoid is still hooked up, even though it isn't. you would have to measure the impedance of the solenoid though, i think the resistor included is 39ohm. if it is close there is diagrams of how to hook up the load resistor and still disconnect the solenoid when a failsafe is triggered (or the kit is turned off)
MDH-005
Jan 8, 2011 09:01 AM
ETS Michael
ExtremeTurboSystems.com – WA
Sep 16, 2010 03:41 PM
HKSevolutionNYC
Feb 17, 2008 06:02 PM
