Aquamist Success Story Videos
I have been collecting quite a few videos of some great results on Aquamist HFS kits
Here are some of the recent ones collected together in one spot
Enjoy
Al
I am a proud Aquamist Dealer
http://www.youtube.com/watch?v=rWqx_vuPTfo
http://www.youtube.com/watch?v=los-PKsRxD0
http://www.youtube.com/watch?v=e0bz4hQG98Q
http://www.youtube.com/watch?v=hxx8s7X-nj0
http://www.youtube.com/watch?v=Xln8HYZI4pM
Enjoy
Al
Some of the videos he managed to do require at least two people. I noticed he can change gear with no hands!!? unless he is holding the camera with his mouth and the other hand did the steering?
How did he do the zoom with his mouth?
No this can't be it, he narrated at the same time... I am puzzled.
Al, tell us the secret
DynoFlash - In one of the videos, you turn off the Aquamist system and the AEM Tru-Boost flashes with the error message as the solenoid is turned off. Is there anyway to wire this system so that the AEM gauge can still act as a boost gauge when the system is deactivated?
Would it be possible to have it tuned for meth and when the Aquamist is deactivated run on 93 octane alone? Can both of these be incorporated in to one map? I have a pump gas tune from you now, would it be possible to modify so it can satisfy both conditions?
you can wire in a switch to keep the boost controller working when the aquamist is off, but when the aquamist is on, you want it to turn the boost controller off if a failsafe is triggered. that is why you need a toggle switch to give the boost controller power when the aquamist is off.
also, you can set the meth to turn on at a higher boost level and run the car without meth up to that turn on point with the aquamist off. past that point if you tune it for meth, once you turn the meth off you'll be lean. if you run water instead of meth you wont have this problem, but you wont want to run the same boost as you wont have the same cooling anymore.
It didn't look like there was much of a tune done on the 100% run. You can get some pretty astonishing results if you really push a 100% water calibration, but it typically takes a tuner out of their comfort zone to really get the effects though.
Some of the old NACA (old version of NASA) technical documents have some really good info on water injection. Water can literally replace a very large percent of the fuel you use. Just don't run out..... lol.
Is it becoming a common consensus that Aquamist is one of the best systems out there?
i look at a kit from individual component up - the other companies just slap things together and hope for the best.
https://www.evolutionm.net/forums/sh...d.php?t=295728
go aquamist or go home.
there is NO injection system out presently that has the ability to control 100% water injection like the IDC based aquamist HFS-5 - speed and precision and metering of injectant, hfs-5 is untouchable.
From a few studies I have read, I have heard that it is only about 5-15% of the Methanol by volume that you inject goes towards upping the octane. The rest is simply cooling both the intake charge and the combustion process. If anyone has heard this, and knows something about it, be sure to post. I am an engineer, but chemistry is not my forte. I love learning!
I prefer to run a water/meth mixture. The ratio I run depends on the engines maximum Mass airflow, I have a pretty handy spreadsheet I use to calculate it. The Rule of thumb I use is the more max airflow, the larger the percentage of water, the lower (close to stock application) the more alcohol. Too much water on an engine that is not flowing enough air will "bog" it down, similar to the results that Al saw when he ran 100% water.
Good luck all, I am gonna purchase an Aquamist for my personal car soon. I plan on injecting 100% water, as I run on E98 currently. We will see!
