Methanol + water = milky
Old Oct 23, 2007 | 09:19 AM
SlowCar's Avatar
I was in tucson az this past weekend helping vroomevo and zzombae with their Aquamist HFS-5. They run 50M-50W mix.
We got some supposely "100% methanol" from this hotrod shop. It stinks BAD and did not smell sweet like methanol...i did not think much of it.
Anyways when we mixed the meth with distilled water, the solution turn cloudy/milky...and we went ahead to fill the tanks.
Zzombae did some research and found this:
http://www.drverwey.nl/testkit.pdf - page 7
When methanol is contaminated with hydrocarbon eg fuels, it turns cloudy when mixed with water.
We suspect that the hotrod shop is using the same pump they used for race fuels to pump methanol.
We went to a local chemical supply house to get a sealed 5 gallon drum for ~$32, and this stuff smells right Siphon the contamined stuff out and put in this new mix. What a pain
Old Oct 23, 2007 | 01:43 PM
JPSR20DET's Avatar
Good info thanks for sharing...
Old Nov 11, 2007 | 05:30 PM
Labonte MotorSports's Avatar
Good info, also just FYI to anyone:
Good methanol will also have a very slight light blue color to it. When you mix it with water it will also get warm as the meth and water molecules combine.
Best regards,
Dan
Old Nov 11, 2007 | 07:43 PM
SlowCar's Avatar
its gets pretty hot in when mixed in large volume...
https://www.evolutionm.net/forums/sh...anol+water+hot
cmos grade methanol...looks blue in pic but colorless to the eye
Old Nov 12, 2007 | 08:07 PM
dubbleugly01's Avatar
it gets a bit more than just a little warm...
Old Nov 13, 2007 | 06:23 AM
Ultimate CC's Avatar
yea theres been a couple times that I picked up "100%" meth and then mixed it and it was definitely cloudy...theres nothing like pure meth...although i still am partial to the smell of race gas haha...
Old Nov 13, 2007 | 06:31 AM
SlowCar's Avatar
Old Nov 29, 2007 | 07:48 PM
pltek's Avatar
well, what if u use meth like holeshot from powermist which is supposed to pass the water (hydrocarbon) test and after mixing it 50/50 you are still milky?
esevo
43
May 31, 2015 06:55 AM
PERRIN_JOHN
Nov 27, 2009 11:38 AM
bnice01
Jun 5, 2008 08:58 AM
steadly2004
Jan 4, 2008 06:00 AM
Kc2Buk
61
May 5, 2006 12:39 PM
Quick Reply: Methanol + water = milky
