Injection Fail Safe by Labonte MotorSports now available
Old Nov 19, 2007 | 04:33 PM
cfdfireman1's Avatar
ordered
It's on the site but the code for the discount doesn't work. "EVOM20"
Originally Posted by Labonte MotorSports
The Boost Bypass Kit will be on the website and available for order by Tuesday at the latest.
Best regards,
Dan
Old Nov 19, 2007 | 04:46 PM
Labonte MotorSports's Avatar
Our Boost Bypass Kit is now in stock and available on the website:
http://www.labontemotorsports.com/st...ow/BBK-10.html
When used with the Injection Fail Safe (IFS-10), the Boost Bypass Kit will limit Turbo vehicles to wastegate boost pressure in the event the IFS-10 detects any system faults. The fast acting 3-way solenoid adds an additional level of safety for highly modified engines with water/methanol injection.
Best regards,
Dan
Old Nov 19, 2007 | 04:48 PM
The code is EVOM10 for 10% off, EVOM20 will not get you 20% off, sorry.
Best regards,
Dan
Old Nov 19, 2007 | 10:53 PM
welll..
Best regards,
Dan
...it was worth a try. Dam IL sales tax. Now all I have have to do is figure exactly how to fit these units with my SMC system.
Old Nov 19, 2007 | 10:58 PM
SlowCar's Avatar
swagelok
Old Nov 20, 2007 | 08:05 AM
and
Originally Posted by SlowCar
swagelok
alliedelec
Old Nov 20, 2007 | 07:25 PM
SlowCar's Avatar
Old Nov 20, 2007 | 08:03 PM
alliedelec
Old Nov 20, 2007 | 08:06 PM
.com
parts to make your parts play nice with my parts.
https://www.evolutionm.net/forums/sh...d.php?t=247321
Old Nov 20, 2007 | 08:21 PM
Thanks for the link, yep SMC and Coolingmist booth use a low side driver for pump control.
Well you can run the IFS-10 with battery power, there is no device limitation that prevents this. The unit will output +12v on the trigger wire since no flow. Once flow starts and gets above the set-point the trigger will go low. Same mode of operation as the Aquamist.
If your water injection is boost pressure controlled, just need to make sure that the controllers Start psi is lower then wastegate pressure. If your controllers Start psi is greater then wastegate pressure, the water injection system will never come on.
Best regards,
Dan
Old Feb 22, 2008 | 04:48 PM
Keep it safe. If you're running a meth kit, a failsafe should be part of your system.
Old Feb 26, 2008 | 11:09 AM
Lucas@LMS's Avatar
Bump it.
Old Feb 29, 2008 | 09:14 AM
Lucas@LMS's Avatar
To the top.
Old Feb 29, 2008 | 09:26 AM
fostytou's Avatar
EvoM Community Team
Was there any reason behind having the unit go high when there is a fault, rather than low?
I would think going low when there is a fault would ensure that a nc solenoid would be in position if anything went wrong, where by going high if your wire is not connected in the first place you will always be able to boost properly, possibly invalidating the failsafe's action if there is a mechanical fault between the trigger or wiring for the solenoid.
Old Feb 29, 2008 | 03:31 PM
Most aftermarket ignition controllers (MSD, Accel) have an input for timing retard that is activated by the High signal. The AEM has a Noz input that can also retard timing or switch maps. Going from low to high makes the IFS compatiable with these options.
It is a simple bit change I could do to make it go from high to low if you are intersted in one.
Best regards,
Dan
