Injection Fail Safe by Labonte MotorSports now available
Old Mar 3, 2008, 01:22 PM
  #31
Lucas@LMS's Avatar
Bump for a new week.
Old Mar 7, 2008, 10:40 AM
  #32
Lucas@LMS's Avatar
Bump.
Old Mar 7, 2008, 12:03 PM
  #33
evokel's Avatar
how much is the failsafe?
Old Mar 7, 2008, 09:13 PM
  #34
Labonte MotorSports's Avatar
The IFS-10 or IFS-20 are each $139.00. Both in stock.
More infor here:
http://www.labontemotorsports.com/st...onitoring.html
Old Mar 14, 2008, 08:18 PM
  #35
Need to know your flow? Labonte MotorSports has the answer. The IFG-20 is a 52mm gauge that can be used with the Injection Fail Safe (IFS-10) to display fluid flow in Real Time. The built in Peak & Hold feature lets you recall the last maximum injection flow rate. No more guess work when tuning to know your systems injection output.
Available in Red ($74.94) or Blue ($79.95) LEDs
Old Apr 1, 2008, 11:48 AM
  #36
Everything is in stock. The Injection Fail Safe is compatible with other kits. So if you already has an water-meth system, the IFS is a great add on.
Old Apr 8, 2008, 08:15 AM
  #37
EvolvedGTI's Avatar
You have pm
Old Apr 8, 2008, 01:22 PM
  #38
Thanks, Pm'ed back.
Old Apr 8, 2008, 02:20 PM
  #39
EvolvedGTI's Avatar
Order placed. Can't wait
Old Apr 9, 2008, 01:20 PM
  #40
sspaladin28's Avatar
Two Questions:
1. Anyone else had issues with the IFS-10 leaking? Looks like an Epoxy issue maybe?
2. What is the difference between the IFS-10 and the IFS-20?
Old Apr 9, 2008, 01:32 PM
  #41
Registered User
johnny's Avatar
so this failsafe & gauge will work with the snowperformance meth kit?
Old Apr 9, 2008, 02:19 PM
  #42
Correct, will work with snow kits as they were a dealer for our controllers.
Old Apr 9, 2008, 02:30 PM
  #43
Originally Posted by sspaladin28
Two Questions:
There will be no fluid leaks with the IFS, we use a two part epoxy to encapsulate the unit. We now use a fixed shot dispensing system to insure the epoxy mix ratio is exact. If it looks like the epoxy did not set up then possibly an early unit that did not get caught in inspection and we will replace under warranty with a new unit..
The IFS-10 and IFS-20 are functionally the same, only difference are the fittings.
IFS-10 uses 1/4" hose quick connects.
IFS-20 uses -4AN fittings.
Old Apr 10, 2008, 12:37 PM
  #44
Registered User
johnny's Avatar
thanks i'll be ordering my failsafe in the near future, since my failsafe does not work.
Old Apr 17, 2008, 07:20 PM
  #45
ExViTermini's Avatar
I have a question about this unit before I purchase it.
The user set-point would be your base flow, roughly. So like when the kit begins to spray, you would measure this amount, and that would be when the failsafe deactivates. If it drops below it activates.
What happens if the line were to pop off between the failsafe and the nozzle? The flow would go to max flow, is this a user adjustable setting as well? So that if this did happen it could cut you back to failsafe mode too...
Quick Reply: Injection Fail Safe by Labonte MotorSports now available
