Injection Fail Safe by Labonte MotorSports now available
Old Apr 18, 2008 | 07:45 AM
  #46
Labonte MotorSports's Avatar
Originally Posted by ExViTermini
I have a question about this unit before I purchase it.
The user set-point would be your base flow, roughly. So like when the kit begins to spray, you would measure this amount, and that would be when the failsafe deactivates. If it drops below it activates.
What happens if the line were to pop off between the failsafe and the nozzle? The flow would go to max flow, is this a user adjustable setting as well? So that if this did happen it could cut you back to failsafe mode too...
Yes correct. The IFS has an overflow limit in the software, not user adjustable. If the line was to come off between the IFS and nozzle the IFS will also activate.
Best regards,
Dan
Old Apr 18, 2008 | 11:02 AM
  #47
ExViTermini's Avatar
Best regards,
Dan
What is the limit set to? I'm thinking most of the kits only flow about 1L at free flow(not sure, correct me if I'm wrong please)? I see you say the unit is accurate to 2.5l, but what is the overflow limit set to?
Old Apr 18, 2008 | 11:37 AM
  #48
Don't know about all the other kits, most use some variation of the Shurflo pump. Our system will free flow about 2000ml/min in 1/4" line.
Old Apr 22, 2008 | 07:48 PM
  #49
mcwop23's Avatar
any new discount codes?
Old Apr 23, 2008 | 10:34 AM
  #50
No new discount codes at this time.
Send me a PM about what you are intersted in.
Old Apr 23, 2008 | 10:53 AM
  #51
BTW, thanks again for the help! I ordered the ifs-10 and its due to be here tomorrow, very very fast service!
Old May 20, 2008 | 08:34 PM
  #52
Bump for more Injection Fail Safes in stock.
Old Dec 2, 2008 | 04:55 PM
  #53
evo8fl's Avatar
The IFS-10 or IFS-20 are each $139.00. Both in stock.
More infor here:
http://www.labontemotorsports.com/st...onitoring.html
did the price when up?
Old Dec 3, 2008 | 09:17 PM
  #54
Price increase went into effect in October. The IFS-30C is a new version that includes the BBK-20 and adds additional level of protection.
more info here:
http://www.labontemotorsports.com/st...w/IFS-30C.html
Old Mar 9, 2009 | 11:36 PM
  #55
wizzo 8's Avatar
Can I hook up a switch to indicate a false failsafe? This way if I valet park my car they cant get full power?
Old Mar 10, 2009 | 08:44 AM
  #56
Sould not be to hard to do. Do you have the IFS-10 with the BBK-20?
Old Mar 21, 2009 | 08:41 PM
  #57
wizzo 8's Avatar
Yes I have the IFS-10 but have the older version boost cut valve that is made by delco. So this wont be a problem? Has anyone done this before?
Old Jul 15, 2009 | 10:07 PM
  #58
wizzo 8's Avatar
Just wanted to add that Dan has very good personal customer service. He stands behind his products. He helped me out with my failsafe issues and took time out of his personal time to do it. I will always recommend Labonte products and will always use Labonte products in the future.
Thanks again Dan
chaotichoax
Apr 13, 2020 12:55 AM
CO_VR4
Nov 23, 2016 05:35 PM
Richard L
149
Feb 27, 2016 04:01 PM
Richard L
61
Jan 21, 2016 06:20 PM
EvoTio
34
Feb 19, 2006 10:08 AM
