blowing Meth during startup???????
r u sre u sent to the correct place?
also i think i may have solved the gage issue with it not wanting to turn back on. for some reason if u use your nail and push it off to the left, it seems to turn on right away. but if u push with ur finger and dead on, it wont. very weird.
I am going to delare the modified DDS board "missing in action", deceased and lay it to rest. It was sent on the 19th December 2007.
I am making you another one. I have a question, what sort of time delay, considering all the preparation you need to turn the key be between the key position #1 to #3.
Rather disbling the entire system (no visual indication at all until timer elapsed). I suggest allow the DDS3 to light up as normal and use the "tank level" indicator as the timer indicator. It goes off when the timer has elasped.
Let me know ASAP. Perhaps pm me your postal address once more meanwhile.
