What are your ideal failsafes?
Hey guys, been working on a new alky kit which will be controlled via the stock ECU (hackers rock...aka Tephra) and uses a fuel injector setup rather than a nozzle.
My question is, what are your IDEAL failsafes? Meaning, what features ARE on the market that you like and which ones are NOT on the market yet? I'll update this post with a list of failsafes as you guys list them. Any help is appreciated.
Alky kit info (hasn't been fully updated yet)
Jamie
FAILSAFES
*All failsafes will trigger a safer fuel/ignition and boost map
Jamie
FAILSAFES
- Low tank level
- Low or No fuel pressure (possible leak, possible clog, pump failure)
- Low fuel flow (possible leak, possible clog, possible faulty injector or pump)
- No fuel flow (failed injector, clog)
- Lean AFR (possible low flow or pressure, faulty injector)
- High EGT's (possible lean mixture)
I think the first and foremost is "direct" monitoring the flow against a reference. All the "indirect" failsafes are the consequence of the "direct" method, why repeat it.
M50/W50 might show up well on the AFR unless your project is confined to 100% methanol.
Good point but i never said anything about a tuner, just that for me personally you can't beat an ecu when it comes to a failsafe standpoint...whats better than having nearly all the values monitored at all times...
If the PCM ECM knows that the tune is based on a second fuel system being used and can except inputs then yes it works really really good. The best example I have seen is the Hydra system for the WRX's.
The stock PCM can deal with knock as these are calibrated frequency's that the PCM has been programmed to look for.......no auxiliary fuel systems being used. But on a car running a tuned lean fuel trim with an auxiliary methanol injection system that the PCM does not know about and possibly the tuner has raised boost over stock or taken stock control away, the PCM does not compensate well for methanol injection system failure in this instance. Yes it can see knock and pull timing but thats not the same thing for high boost, then sudden lean and high EGT.
This would be the ultimate in monitoring and the hardest part to make into a reality.
Since my control unit monitors all of the basic failsafes and simply triggers the safer FUEL/IGNITION and boost maps if any are triggered, I only need one ECU input to cover all of those bases. I simply need one more input for the flow monitoring. Then its just a matter of setting up a table in the ECU to watch things.
The plus side is that you can actually datalog these readings too if it gets implemented.
Well the Labonte unit is $139USD, and has a resolution of .1 to 2.4 volts I believe, from 100cc/min to 2500 cc/min. The DDS3 definitely has greater resolution (I'd need the 100 cc/min-1000cc/min scaling) but I couldn't find a cost on the DDS3 unit. Does it only come with the controller gauge?
The DDS3 is a gauge controller so to speak
$297.00
http://www.aquamist.co.uk/press/
top of the page click the link for the manual
$297.00
The two ends are 1/8BSP female - I am sure you can find a AN/BSP converter somewhere.
http://www.aquamist.co.uk/sl/plist/frm-4-USD.html
http://www.theperformancedriver.com/...productid=3720
Nice find on those fittings. As long as those fittings are not over torqued into the flow sensor (easy to do if use gorilla hands) I think there good.
Because of the way AN fittings work (needing to be very tight to make a seal) I was thinking that if you installed the fittings onto the lines first and then screwed in the assembly into the flow sensor you can better avoid possible damage to the sensor from over tightening.
Richard L
106
Dec 14, 2018 02:16 PM
Shaun@AWDMotorsports
Jun 14, 2016 10:34 AM
Richard L
61
Jan 21, 2016 05:20 PM
SlowCar
13
Nov 29, 2007 09:08 PM
smokedmustang
46
Feb 6, 2007 01:24 PM
