ATTN: Richard L and other Aquamist users
so like most of u know if u read my thread about blowing meth during start up, i have had to turn the system off before i start the car so that it wont blow meth. this is happening more and more i am noticeing when its cold out. so when i turn off the gauge, this happens....... watch
http://img532.imageshack.us/my.php?i...ture015zm4.flv
please help. is it the gauge or something else? u can get it to turn back on but its not easy. also when it was first installed this happened back in Sept. but when i got it back on i left it on so i didnt have to worry about any more headachs. well now the headach is inevitable.
I think it's broken? I'm sure you can send it in and they'll get you a new one. Kinda sucks though depending how you wired it, alteast it's all bunched together.
Also I have turned mine on and off a bajillion times and this hasn't happened.
when i say "blowing meth" i mean its actually spraying when cranking over the motor when its cold out.
and i think there is something wrong with it as well. Richard can u help me and advise me on what to do. thanks guys
have you verified that it is actually injecting meth? or just going by what the gauge says? i would try removing the nozzle from the intake, have a buddy aim it into a cup, and then start the car and see if it squirts meth. if it doesn't and the guage still lights up you know it is the guage or some other electrical "noise". if it is indeed injecting meth it at least lets us know what all the symtoms are.
do u have anything to say about my gauge?
The gauge:
It appear that the side of the button could be rubbing against the opening of the front panel. Unscrew the front bezel and re-align. The front layer is held on with semi-sticky back - can be re-position as many times as you like.
The cranking spray:
I can modify a DDS3 JB with a power-on delay - I think this can solve the problem. Pm me you address. It will take me a few days to implement the change.
The cranking spray:
The gauge:
The cranking spray:
The cranking spray:
about the DDS3, i didnt install it and to be honest with u, i dont even know where they installed it in my car. i have looked in the glovebox, under the dash and i cant find it. so i will have to ask them where they installed it.but i can pm u my address anyways.
i tried taking apart the gauge and the botton isnt stuck from what i saw. its almost like it wont click home to stay on. now i can get it to stay on but it takes me like 300 pushes or so until it finally stays.
If you loosen the three screws holding the panel and perhaps you can re-align the button better. Check first if the plastic front plastic panel is align well with the metal backplate.
Spythere
Jul 5, 2016 03:09 AM
LancerOzClint
23
Apr 26, 2011 10:44 AM
