Under-hood water injection?
Does Buschur make the only under-hood alcohol injection kit?
I'm looking for a simple, basic, mild H2O kit that fits under the hood. Has anyone figured out how to mount another kit under the hood? Has anyone figured out how to use the stock I/C sprayer jug as a W/I tank?
Just about every company including ours makes an underhood kit. Our Vari-cool stage 2 kit for example is an underhood with a tank, you can even tap your existing tank instead of using the supplied tank. I believe that the SMC kit that have pictured is probably the only kit that has a pump that mounts IN the windshield washer tank. The disadvantage of that setup is the pump is very small and does not have the same pressure ratings of the shurflo units.
David
David
Has anyone used either of these water/meth kits along with the stock I/C spray tank?
EngineRunup $199.99
Coolingmist $212.95
EngineRunup $199.99
Coolingmist $212.95
Jim- Its Evan I have the White RS and was speaking with you and Faisal at the IA meet....
If your going to do watermeth injection, then your messing with engine reliabilty (more boost,ect ect) Going cheap on this feature should not be an option. If your planing to use this just for the added feature then I would go with the 1S Aquamist system. On my EVO 8 I had the whole system installed under the hood! If your going more for the raw power from the kit then the HFS'S would be good.
Aquamist not only has the best customer service and MOST proven history with their kits, They also have the best failsafes, and features. You can get them from IA or VIVIDRACING (I work there )
I currently run the Aquamist 2d in my personal car and have the whole kit in the engine bay. If you need help pm me be glad to help with the install as well! Good luck!!!
Our system can be installed completely under the hood, including the controller. The VC-25D injection controller was designed specifically for Mitsu engines.
http://www.labontemotorsports.com/st...ntrollers.html
If you are going to run more then 50% meth, trunk mount is recommended.
Let me know if you need more info or have questions.
Best regards,
Dan
kpt6
Sep 22, 2015 08:40 PM
sith_killer_99
Sep 6, 2012 12:34 PM
