Making a MAC solenoid Plug & Play
Try measuring the MAC valve again.
The Zavt output grounds a relay. Relay when grounded...powers any 12v device, ie mac valve. Good idea with the resistor...i don't have mine wired directly to the dds3 board. I use my DDS3 exclusively for map switching and flow sensor and i guess boost switching in the near future.
why not use the output from the ZAVT to switch maps on the ECU. You can get a normally closed relay that you connect to the ZAVT. You wire this relay in line with the output from the DDS3 going to the map switch harness. It will work so that if there is no ground from the ZAVT, the relay is closed and power is able to flow from the DDS3 into the ECU to switch maps. Then if there is a failure the ZAVT provides a ground signal which makes the relay drop the connection. Now power can no longer flow from the DDS3 into the ECU, and you switch back to pump gas maps.
I prefer to use electronics rather than extra boost controllers. Personally I find that whenever I try to use more than one boost solenoid it just complicates things and also makes the system respond slower as there is now a lot more vacuum line. Plus more vacuum line = potential area for leaks.
I have mine hooked up to another switch so that I can change maps manually even if my DDS3 is turned off. Useful for testing or for race gas map
Evo_Jay
Nov 1, 2018 10:01 AM
maperformance
Dec 16, 2014 04:57 PM
EvoPower81
11
Jun 2, 2014 08:07 PM
AWD Motorsports
AWD Motorsports - Florida
100
Sep 22, 2011 09:41 AM
