Water Injection Calculator !
http://www.customperformancesolution...injectioncalc/
I'm running a single 1.0mm jet on my max'd out IX turbo and recently switched to E85 and saw some performance gains. This is a great tool to help you (and me) figure out what different jets should be used for optimal fuel percentages. I'm thinking of adding a 2nd jet (.5mm) to bring it over the top.
Hi guys,
If someone need an offline version, I made a replica in XLS format...
Hope you will envoy it...
Any improvement to original file will be appreciated!
Version 1 is HERE
Cheers!
Version 1 is HERE
Cheers!
I have been reading thread after thread on selecting the correct Jet and restrictor size but don't seem to be getting it. I am running a IX turbo with stock injectors and will be setting up an HFS-6 system with a 50/50 mix. I am a little lost on how to know what my Injector/Fuel Rail pressure are and what the duty cycle will be? Can someone give me a how to determine jet and restrictor size for dummies?? Thanks for the help.
Most of those values you leave as-is. Stock injectors flow 560cc's and you have 4 of them. You need to log your car to see what your peak IDC is but if you have a walbro and all the mods listed in your sig, you're prolly running about 100% IDC peak pretty easily (not bad, I ran mine up to 127% ).
Anyways, decide how much meth/water you want to inject and set that percentage, or guess at what jets you want to run and work your way backwards. Last week I switched from a single 1.0mm jet and added a second jet. I was going to add a .8mm, but all I had was a .9mm so I just went with it. That adds up to 967cc/min based on the chart listed on that page. I'm using 2 injectors, so divide that in half for 483.5cc/min per injector target (average). With my setup and some rough numbers, that gives me about 22% of my fuel ratio being water/meth. Since I'm going for max power out of the setup, this is a good % to be at
I attached a screenshot of the settings I used. Again, rough numbers but they work.
