pics showing meth corrosive
Do you spary 100% meth right now or 50/50? It looks like corrosion (water and brass dont like eachother, oxidation) to me which may be from 50/50 or water in the washer fluid that you have used before....
The water may be the issue as I said before if you are running it with water then you may have corossion on the brass nozzle because of the oxidation. Left over meth/water mixture may be pulled out of the line while at idle and turning the car off and just sitting there for a period of time...... Im not saying that I'm 100% right but it makes sense as a possability.....
The coloring on the outside of the pipe looks like dye from washer fluid. Possible a very small amount is seeping past threads of nozzle and elbow and leaving a stain.
Inside of pipe looks like hard water deposits from minerals that might be in the fluid you used.
Are you taping your boost reference source before or after TP? If before, try moving controller boost reference to after TP. You will see faster off time of spray when TP closes. Else when TP closes you still have boost for a spit second before BOV opens which would explain the reverse flow you are describing.
Best regards,
Dan
Best regards,
Dan
ya sucks that the labonte kit came with brass. I will order a stainless one. thanks everyone. Also will never use windshield cleaner fluid due to the quality of water they use and that dye. I use 100% distilled water and Methonal.
hope my thread helps others.
hey dan,my boost tap is after the TP. I used the Fuel pressure Regulator.
Do you sell Stainless nozzles, if so i would like to order 1.
Best regards,
Dan
Best regards,
Dan
Where exactly are you seeing corrosion, cause I don't see any......
1. green stuff is from whatever fluid being used
2. your nozzle is leaking, pressure test and check for leaks
3. no way a 60/40 mix is going to cause corrosion after a few months. I've been using 100% for years and been through 1 pump that was corroded.
4. always mix meth/solution w/ distilled water
Best regards,
Dan
Best regards,
Dan
