DDS3v10 & Tephra/Jack_of_Trades cable
Hi,
Has anyone wired this up yet? I just got the kit in, and am trying to figure this out. I noticed the v10 has a +5v out (pin 5).
Thanks in advance
-Jason
Thanks in advance
-Jason
With the v10 kit you don't need the jack of trades harness.
I currently have the v10 kit with pin 5 wired directly into the ECU on the alt map pin.
The DDS3 v.10 outputs a steady 4.5v which works perfectly for switching maps.
The jack of trades harness outputs about 4.75 which also works fine.
dudical26,
can I out put a signal from a dds3 through the Jack of Trades harness? I have the original dds3 from the "5" kit.
I was using a ground signal from the dds3 to trigger an ebc but now I am using the stock boost control and going to an alt map.
now I have a JOT alt map switch harness
I figure I can relay to the JOT switch going to 12v from the ground signal and then the JOT harness would fix the voltage to the ecu? Thus removing the switch out of the harness.
Is that clear? will it work?
konstantinosIX
Mar 22, 2009 10:09 AM
