Aquamist flow low after 3 months of no use.
Old Dec 19, 2009 | 05:45 PM
  #31
dubbleugly01's Avatar
I had a HSV slowly deteriorate on me till eventually it was fully evident. I thought my tune was chaniging over time, and had to start dumping more fuel as a/f's were leaning out. Put a new HSV in, and I was pig rich. It took a couple months to go from normal to erratic to total failure
Just another option in addition to what Richard has listed. Doesn't explain why it occurs in only cold weather, but mine was a bit erratic to begin with before total failure. If you're on straight meth with the age of the kit, it's something to consider.
Old Dec 20, 2009 | 02:05 AM
  #32
Richard L's Avatar
This is another possibility, but not strictly temperature related. We can also add a temperature compensated circuitry to add more duty cycle to the HSV.
Do you have the failed valve? Perhaps ypu can send it to me for close examination.
Old Dec 20, 2009 | 08:05 AM
  #33
Richard,
I did send it back to you, it was about this time last year. I never heard what you learned from that examination??? It came from Houston, Texas.
Old Dec 20, 2009 | 10:36 AM
  #34
Richard L's Avatar
I will look back.
Old Dec 20, 2009 | 06:26 PM
  #35
scheides's Avatar
EvoM Moderator
These are list of possibilities:
1. Pump changing pressure
2. Nozzle size reduced (freezing of the tip)
3. Increase viscosity of fluid reduce flow through an fixed orifice.
4. Lift of the inline valve reduced
5. Flow sensor reading error
Which is most likely?
1- can be tested, lets work on a way to try this. I'm willing to buy some hardware if needed.
2- somewhat unlikely due to being in the engine bay, pretty warm in there...could test this somehow I bet, let me think about that one more
3- even with increased viscosity, would the flow be lowered? Not necessarily, if the pump is still up to the task. Pressure would likely rise though, which would go back towards something with #1
4 - Interesting! I am intrigued by this one...I have the valve in the cabin though, so it would have to be really really cold, the reduced flow does not get better if the car is driven on a long drive and really warmed up (I will be mindful of this and verify)
5 -not the case as I've seen the AFR lean out on my wideband, about half of a point.
Old Dec 20, 2009 | 07:13 PM
  #36
Jeff H's Avatar
Due to the relatively large coefficient of expansion of plastic, could the tubing be shrinking smaller in one of the fittings between the tank and pump allowing a partial loss of prime of the pump? The symptoms sound like other I've seen that have a priming issue, but yours is related to the cold temps. Maybe the vacuum of the pump is drawing air in somewhere, reducing flow? You check for small bubbles in the line before the pump.
Old Dec 22, 2009 | 10:23 AM
  #37
scheides's Avatar
EvoM Moderator
I have a HFS-1, so this can't be the problem, can it, unless it is simply not opening far enough.
scheides
271
Jan 6, 2013 11:06 AM
TTP Engineering
Jan 26, 2010 05:56 PM
scheides
Aug 31, 2009 05:34 AM
scheides
10
Jul 3, 2009 09:20 AM
scheides
101
Mar 30, 2008 07:50 PM
Quick Reply: Aquamist flow low after 3 months of no use.
