Methanol suppliers
Have you checked the local forums for where you are located? You can usually find a distributor locally. If you can find a petroleum-type business they might sell it to you for cheap if you buy in bulk.
Are you running 100% meth? If you are running 50/50 you could go here: http://www.alcohol-injection.com/pre...4a4120b702e983
Go to your local auto parts store and buy HEET. Its meant to remove water from fuel lines, but its almost 100% meth. It comes in a yellow bottle.
Unless you have somewhere to get VP meth, I would use HEET.
I wouldn't use HEET or washer fluid. You never know exactly how much meth is exactly in there. Plus, there can be other additives as well. If the ratios are off and you are tuned on a specific mixture, it can really screw things up.
I wouldn't buy anything but a pre-mixed solution or straight meth, depending on what you want to be tuned on.
^^^Canexican is 100% correct! (awesome alias, btw) You will be tuned for a specific mixture % and if that fluctuates you could really screw yourself. I'm not saying it couldn't work as I don't know HEET and how often that fluctuates but I would not recommend a true unknown and have a fellow user go super aggressive on a self tune that literally blows up in their face.
call VP fuels close to your area and they will give you the number to a shop that will sell it to you. I just did today and was prepared to drive 2hrs until they told me there's a shop 2 minutes from my house. I called the guy and i am picking up 5 gallons tomorrow. It is the M1 100% methanol.
