Nozzle size Question
http://www.labontemotorsports.com/da...ozzleGuide.pdf
According to Labontes site, an M10 nozzle would be used to support 25+psi and 600hp at the flywheel. I presume to be around there when I do my Red and will be at 30+psi.
Do we say do an M10, or an M14? Using Alkycontrol's shurflo pump which is set to output 150psi I believe and will be running meth/water or denatured alcohol/water.
m10 and your good to roll
I just picked up a kit from my friend that has an GSX... It's DevilsOwn meth injection, the kit is a dual nozzle one is a 7 nozzle and the other is a 10 nozzle... I'm boosting 26 psi stock turbo making 331whp you guys think that's safe? It's hooked up right now but not running think I have a pressure sensor problem
LCS
Feb 24, 2016 01:35 PM
DaGermanEvo9
Dec 11, 2011 08:13 AM
4DOORGALLOR
Jul 19, 2010 09:18 PM
ecuflasher
Jul 12, 2008 02:55 AM
