San Diego Evo's
#4052
got the car back tune is rough till i get everything done, it wouldn't run with the sparktech ignition so i guess I have to call them and figure out what the problem is the coils keep grounding out to the mounting plate. Also and suggestions on a good alignment shop near santee- rancho santa fe area
#4056
With oil prices falling from $150 a barrel to $105 and should go as low as $80 a barrel, I'm going to need a duel map set up. E85 and 91oct, using a toggle switch, just need to get re-tuned on the 91oct with the 1000cc. should be the best of both worlds. James, hook a brotha up!
#4057
#4058
so horrible first day with the evo, first in traffic it over heats unless the heater is on, the alignment was bad!!! Rush is taking car of that in the morning. The front brakes don't work !!!!! so that was exciting and the tune is so rough that hill with no boost is impossible i would rather drive a corrola so back to Garage GT! Until it is 100% done f this break in business. On a lighter note those BF cams are beasts 10 inches of vacuum at idle! holy lopey
#4062
The Broncos played a good game. The Chargers can obviously score big points, but their defense is crap and are giving up too many points. Their loss yesterday was their own fault because they shouldn't have put themselves in that position. However, they got screwed over by 2 calls, one of which flat-out cost them the game no matter how horrible their defense is. Oh well...scoreboard.
