San Diego Evo's
#959
Thanks for the tip on the visual part of the smog test! Ic pipes? That's what carb eo stickers are for! I need to check if my injen uicp has it (supposedly some do and some don't). Good news on the motor mounts and battery. I wonder about other things like spark plug cover (easy to remove anyways but still curious) and ingalls stuffy. Pretty sure those fall into the same category since they are not "engine enhancements"
#960
yea brah, you outta be strait with tht stuff. i have a carb number on my car for my injen uicp, and intake, but its only cause i know francis and janie over at injen, so they hooked it up.
as for the little dress up mods, you should be fine, but at the same time, i woudnt want them to see that plug cover, or the polished heat sheild then in turn, they get the feeling they need to look a bit harder to make sure there nothing else funny under the hood there.
To play it safe, just make it look as stock as possible. IC pipes and all.
