Help....Temecula evo owner needs immobilizer removed
My car had a ghetto alarm installed poorly when I bought it so i decided to remove it. While I was removing it I believe I accidently removed the Immobilizer. The car will crank but never turns over. I cant hear my fuel pump anymore. I tested the fuel pump wires and when the key is in the on position I have power at the pump. Can anyone in Temecula remove the immobilizer from my ecu with their ecuflash? Please help. If this doent sound logical, im open to any suggestions as to why the car wont start anymore.
If its not the immobilizer than what could it be? 2004 evo8 stock other than 255 fuel pump and aem intake. I just replaced the cam position sensor because it was cracked. I was thinking that might be the problem. Basically i removed the cheap alarm that was installed and the car worked fine for a week. Probably 5 starts. Now it wont turn over. anyone have suggestions? I wanted to remove the immobilizer from the ecu so that I could eliminate that from the list of potential problems.
