considering P2 flash for my 05
Originally Posted by jansolo
HAHah! I figured you guys, of all the tuners out there would be the ones to figure it out. So the next question is: is there launch control for the 03 and 04 Evos as well, or is this feature relegated to 05s only? And can existing customers with P2s get the update for launch control?
All existing P2 customers will have the option of switching to the P2R to incorporate this feature AND it will be available to them at no additional charge If you wish to alter the default setting of 5K to an RPM of your choice, it will run $49.
Sorry to keep pestering you guys, but I'm still a bit new to the Evo platform: since the P2 flash will improve boost control through the ECU, does that make a boost controller (electronic or manual) an unneeded mod? When I buy the P2, can I ask for a specific boost level (assume an upgraded fuel pump and rail, everything else stock)? Thanks again!
Originally Posted by Jamie@WORKS
Yes, external boost controllers (electronic or manual) are not necessary as the P2 will set the boost at the maximum safe value for whichever grade (91 or 93 octane) fuel you run. Custom boost levels haven't been offered as we haven't seen requests to bring boost below the OEM level.
Originally Posted by KazzEvo8
... so don't do a clutch drop, jan ...
Why would I want this 2stage cut? I have an '03 and don't yet see value in it ... ?
https://www.evolutionm.net/forums/sh...d.php?t=114343
I went there on Thursday to upgrade my P2 but was told it is not available yet. :
Just a thought
-S ...
Originally Posted by jstockdale
Next time call first maybe? Instead of just going without talking to WORKS and then being disappointed ... then posting negative comments on the boards?
Just a thought
-S ...
Just a thought
-S ...
I did call first........ and was told it was available. Then I drove down to WORKS.
