WORKS - California WORKS is a tuning shop that specializes in the Lancer Evolution. They in-house design performance products for the Evo, so if you have a request come on in and let them know! [Visit Site]
269 cam lifts
Old Sep 1, 2004, 11:43 AM
  #91
boomn29's Avatar
Originally Posted by EM@WORKS
Should you get the springs and retainers at the same time? Hell yes! They might not be "needed" for the WORKS 269 Power Cams, but there are a lot of benefits of going to the upgraded valve train.
One of the most obvious is to be able to rev higher. The WORKS 269 Power Cams have a much greater top end than stock, and will still make good torque pass 8000rpms. With the WORKS valve train, you can go there and back everyday, or even higher! (as high as 8500rpms!) Higher Revs with a matched cam will make more power.
With the 269 cams......without the upgraded Springs/Retainers, we can only go to what level safely....7500rpms??
With the upgraded Springs/Retainers, we get access up to 8500rpms. Does the power range increase from redline up to 8500rpms, or are we just able to rev that high and the power stays consistent (thereby allowing up to stay in the upper rpm's more)???
boomn29 is offline
Old Sep 1, 2004, 12:22 PM
  #92
ez76's Avatar
... there are a lot of benefits of going to the upgraded valve train.
So you feel confident the stock bottom end is happy revving that high?
ez76 is offline
Old Sep 1, 2004, 01:30 PM
  #93
jj_008's Avatar
Abrupt gas expansion cools the exhaust gases rapidly and creates undesirable turbulence... back pressure. It's pure thermodynamics we are talking about here. This has been tested; we made it 2.75" for a reason and it wasn't cost. (2.75" material is more expensive than the more common 3")
We are talking about the downpipe. I repeat: the stock O2 sensor housing outlet is very small (2.5"). This is why the 2.75" DOWNPIPE works best, with whatever catback you have. There is LESS backpressure (read: more power) with the 2.75" downpipe partly because of the O2 sensor housing outlet.
I hope this helps you understand. The 2.75" down pipe was engineered to work best with the stock turbo and stock O2 sensor housing. Moving up to our Cast O2 housing with 3" outlet and our 3" downpipe will result in good power gains. But not the 3" downpipe alone.
But boomn29 is right. We should reserve this thread for the original topic. We will be more than happy to discuss fluid dynamics & thermodynamics if you want to give us a call or check out www.asme.org or www.sae.org.
Best response I have read in a long time. I think some people need to sit through 1 year of thermodynamics and fluid dynamics before they respond. Even though I don't have any WORKS products on my car, it is good to see a vendor actually using some engineering to make its products.
jj_008 is offline
Old Sep 1, 2004, 01:45 PM
  #94
mayhem's Avatar
I just ordered my 269 cams/sprints/retainers yesterday.
mayhem is offline
Old Sep 1, 2004, 02:20 PM
  #95
TylerO@WORKS's Avatar
Originally Posted by boomn29
I thought the P2 removed the rev limit altogether?
Nope, we raise it to 7800rpms. Custom rev limters are available if you like.
TylerO@WORKS is offline
Old Sep 2, 2004, 12:30 AM
  #96
ez76's Avatar
One of the most obvious is to be able to rev higher. The WORKS 269 Power Cams have a much greater top end than stock, and will still make decent torque past 8000rpms. With the WORKS valve train, you can go there and back everyday, or even higher! (as high as 8500rpms!) Higher Revs with a matched cam will make more power.
I respect that you have the conviction to make this claim. Can we please see dyno graphs of stock head, stock turbo Evos with your cams making "decent torque" past 8000rpm?
And I have to bump my question about your opinion of the stock bottom end's being able to handle 8500rpm, as this goes against what pretty much every other respected tuner has stated about e.g. our rod bolts.
ez76 is offline
Old Sep 2, 2004, 10:11 AM
  #97
The valve train will handle high revs with the upgraded WORKS parts. The stock bottem end is a different story. If you want to go to 8500rpms every day and not worry at all, build the bottem end to take it.
Old Sep 7, 2004, 11:58 PM
  #98
GokuSSj4's Avatar
so whats the most you can rev the motor ?
with cams and valvetrain and stock hear. block and turbo
GokuSSj4 is offline
Old Sep 8, 2004, 04:37 AM
  #99
4ce fed's Avatar
Are there any dyno sheets of these cams? Before and after? Everyone keeps saying they "feel " better and faster. I would like to see the improvement in the area under the curver (torque) throughout the RPM range. I am sitting on the fence on which cams to get. I want the most improvement in the lower RPM range and under the curve. Not peak HP numbers. How do these compare to the HKS in that regard?
4ce fed is offline
Old Sep 8, 2004, 05:39 AM
  #100
David@Vishnu's Avatar
Thanks for clarifying why the claim of these HUGE rev limits then? How do you all feel about 8K?
David@Vishnu is offline
Old Sep 8, 2004, 06:22 AM
  #101
sir lurks alot's Avatar
7800rpm is where my fuel cut is set at.
sir lurks alot is offline
Old Sep 8, 2004, 09:42 AM
  #102
drmosh's Avatar
Don't you and your crew have some dynos to recalibrate?
Or temperature probes speaking of "claims"...
drmosh is offline
Old Sep 8, 2004, 09:51 AM
  #103
GokuSSj4's Avatar
blahhh!!!! lol
GokuSSj4 is offline
Old Sep 8, 2004, 02:42 PM
  #104
Coolguy949's Avatar
It's about time.........i was wondering where the trolls had gone to.
Coolguy949 is offline
yitzac1990
08+ Lancer Show / Shine
12
Apr 13, 2010 08:52 AM
mrbishi
Oct 15, 2009 09:47 AM
boostedlaser
May 18, 2009 11:03 AM
voidhawk
Mar 22, 2009 07:13 AM
ashumo
Jun 2, 2005 01:09 PM
Quick Reply: 269 cam lifts
