Works Rear Swaybar Review
Quality is top notch and it makes a world of difference. I picked this up after reading a review of another swaybar's results in a popular magazine. What they said is true, firming up the rear end is what this car needs. Only problem is that its a bit of a pain in the *** to switch it out on the Evo. You really do have to disconnect one of the lower control arms to put it in. I would say this sway bar made the same size difference in the character of my car as the P2 did. Highly recomended.
Rest is stock. 0 toe, -1.5 front, -.6 rear camber. The car is much easier to rotate now. There are some onramps, turns and corners aound here that I take quite often and this bar made a huge difference. The car still understeers in the real tight stuff, like in the parking lot, but on the onramps its awesome. You can step the back end out much easier and steer the car with the throttle. Neat stuff.
With a 24mm bar it's possible to get it in without unbolting the control arm but it's a monster PITA!!! Took me at least 20 minutes (each) to take out the stock one and get in the new. Definitely worth it.
How did you get it on without dropping the control arm?
Or should I ask, how big of a hammer?
Just got my sway bar in today and the difference is actually very noticable, though I have a bit of money put into my suspension (coilovers, rear strut tower bar and different lower tie bars). I was taking an on ramp right after I got the bar installed and the back end seemed to be more compliant and I was able to basically take the turn with even less effort. What setting did you put your rear sway bar at?
Originally Posted by slt
I keep mine on the middle section. My car spun in the rain a few months back and I don't want to repeat that. Aluminum links are expensive.
I have a 24mm hollow rear bar (lighter than the stock bar) which, while stiffer than the stock bar, is not as stiff as a solid bar. That's why I feel confident setting it at full stiff (still has a touch of understeer, but not much). See my site for more detail:
http://cracknut.com/cars.adp (top 2 links mention the swaybar).
I'll have a more thorough handling analysis from the 6/30 EOC event at Streets sometime later this week.
As for the installation, first I removed the muffler. Then I tried to install it when the car was on ramps but couldn't get it. I realized the control arm didn't have to be unbolted if I could get a bit of drop at the wheel. So I put the car on jackstands and voila, I could finish the job. Whole thing took ~3.5 hours including breaking the fast and modifying (dremelling) a couple parts (not the bar itself but an associated washer/bolt).
Tyler or Jansolo - can you host a couple high-quality videos for me? They are the videos of the soundes I posted earlier. Plus I have a video of the Defi boost gauge showing P2+exhaust (23psi peak, drops down to ~21 sustained).
Kracka
51
Apr 7, 2012 03:29 PM
